99 F-250 Engine Removal
So, i just purchased a 99 f-250 5.4L 4wd that ended up having a seized motor. I have a 99 f-250 5.4l 2wd that has a good motor in it and plan on doing a swap if everything matches up. Has anyone had experience with removing these motors without pulling the cab. Is it possible to do it without removing the cab?
Yes, you can do it without removing cab. Remove the radiator, condenser, grill, header panel, and top header bar. It will come out through the front.
It is easier for me to remove the cab because I have joint problems and I don't like leaning over and under the body, but normal people just pull it out front.
crookland
03-19-2002 03:50 PM
