1995 Ford F-350 7.5 460 misfiring / no power / stalls
Long story short I ended up purchasing a 95 f350 dump truck gas 7.5L 460 engine for a good price..
the truck was running fine I let it sit for a few months once I went to start it up the starter wasn't clicking so I tested the solenoid and it cranked. I couldn't figure out why the ignition wasn't working so I wired a direct connection to the solenoid make it easier
the truck starts right up now and idles fine except when I press on the gas it bogs and stalls out if I hold the gas..
if if I keep lightly tapping the gas eventually it revs all the way up and moves
any ideas?
any ideas?
Your truck may have multiple issues.
But for starters, make sure the truck warms up completely, then run the procedure for reading computer fault codes in the "Key On Engine Off" mode.
If that term, "KOEO" is unfamiliar, your in for a real learning experience, as these trucks, especially the ones for a "good price", end up needing a LOT of specialized attention.
Ask me how I know. (Don't)
But fuel problems are so common, in every part of the fuel delivery system, it's practically inconceivable that yours won't need some attention.
As mentioned, you probably have a variety of issues with your truck, and the first thing you should do is check for codes.
Not all codes cause the CEL to turn on. Make sure you use a spark plug socket with the rubber grommet on the inside to keep from breaking spark plugs. The 460 doesn't use the same spark plugs as the modular motors, so breaking them isn't very likely to happen anyways. You can go to any parts store and pick up a $30 scan tool. It won't be fancy, but comes with instructions on how to run the tests.
cabloom300
03-26-2019 02:15 PM
dbrinson
06-21-2013 09:43 AM
linus72
12-04-2011 06:59 AM
Home Solutions
12-29-2004 08:14 PM
