Alternator....which one? Amp requirements?
Is 100 amp what I need? I know these trucks need a fair bit of amperage and I don't wanna get stuck with the wrong one. What's the ambulance package got? I'm assuming high amperage and more accessory connections than I need but I don't know. This is my first IDI charging system failure and I don't wanna install some crap that will fail or over charge my new batteries
I upgraded to the 130 3G alternator. In my opinion it is a must. At idle the volt meter doesn't flinch it charges well and is worth the upgrade!!! You won't be disappointed!
www.ford-trucks.com/forums/1156489-how-to-3g-install-for-83-92-idis.html
i also like it because it is internally regulated vs the external regulator
Third on the 3G. I found my 3G in a 90's taurus in a pick-u-part junkyard. Took the wiring harness with me. Only took a half day to rig up. Here's a good tutorial: https://www.ford-trucks.com/forums/8...-pictures.html
I had so many problems with my 1G even after I would change the VR and alternator out. But once I went 3G, never had any problems yet.
For a bolt in replacement a 65 amp 1g is fine. I recommend swapping to a 130 amp 3g as it's only a little more time and money. The 3g is a superior design, the 130 amp will output nearly 100 amps at idle IIRC and oversizing the alternator will ensure it runs cool.
For a vbelt system a 130 amp alternator for a '95 E-150 with 300 six is clocked correctly and has the right bolt spacing on the mounts for our application.
The junkyards are full of 3gs. This is the write up I followed
Piece of cake 3G alternator upgrade - Diesel Forum - TheDieselStop.com
Wrong, these trucks hardly pull any amperage. My '86 pulls 33.1 amps with everything turned on for maximum electrical load. A gas truck will use slightly more for the ignition system. The early trucks came with a 42 amp alternator which was entirely adequate but might not make 14v at idle depending on load.
If you don't want to scour the junkyards, you can just order a 3G alternator from Rockauto and order the conversion wiring off of ebay. Something like this:
Ford 3G Alternator Conversion Harness Connector 1 wire | eBay
Ford 3G Alternator Conversion Harness Connector 1 wire eBay
cheers!
