7.3 idi front crani seal or oil pan gasket?
Old 03-20-2017, 07:47 PM
giorgio.fo's Avatar
giorgio.fo
giorgio.fo is offline
hi guys,
i can't understand if my front crani seal is leaking or the oil pan?
Old 03-21-2017, 08:51 AM
IDIoit's Avatar
IDIoit
IDIoit is offline
if you have a oil pan gasket, that's your issue, RTV only.
also oil can leak through the keyway on the crank snout.
if it was the balancer seal, it would sling oil all over the place.
Old 03-21-2017, 11:22 AM
giorgio.fo's Avatar
giorgio.fo
there is oil on top of the balancer too so i think is coming from the balancer seal and goes all over around.
going to clean up good, let id idld and watch where it comes from.
Old 03-21-2017, 06:21 PM
giorgio.fo's Avatar
giorgio.fo
i have found where the oil comes from
Old 03-21-2017, 06:32 PM
giorgio.fo's Avatar
giorgio.fo
no wait that's the fuel supply pump
Old 03-22-2017, 07:41 AM
cadunkle's Avatar
cadunkle
cadunkle is offline
It could be leaking at the fuel pump to block gasket as well. That one is quick and easy to clean up and reseal. Regardless of whether you suspect the front leak is the oil pan or fornt seal, the front cover must be removed so if the leak is bad enough to warrant fixing, just pull the cover and do the front seal and reseal the cover.
Old 03-22-2017, 05:18 PM
giorgio.fo's Avatar
giorgio.fo
thanks cadunkle,
for now i torqued to speco the fuel pump bolts and one of the water pump bolts that was leaking as well.
looks like it doesn't leak oil anymore. i'll keep an eye on the front crank seal.
i didn't know bolts could get loose like that.
Shawn MacAnanny
12-22-2016 04:29 PM
Katie Ann
3.8 & 4.2L V6
10-08-2015 09:50 PM
oem78
09-29-2010 01:38 AM
novicebob
11-01-2002 05:22 AM
donbarkey
07-17-2001 06:11 PM
Quick Reply: 7.3 idi front crani seal or oil pan gasket?
