Powerstroke wont start
So my daily driver (1996 f250 7.3) sat for 4 days while I was out of down this last weekend. When I returned, I expected it to take a few cranks because it had been unplugged and a bit cooler weather outside. To my surprise it cranks and cranks but no white smoke or anything. It is acting like it's not getting any fuel, any suggestions? My truck is just sitting in a parking lot right now...
1st get a volt meter and check the glow plug relay(under the darth vader looking engine cover) You will want to see only 1 volt difference between the input and output side of the relay(2 big studs)
If more than that, make sure the relay is being triggered. One of the small wires, cant remember which. The ECM GROUNDS the one wire to trigger the relay. The other small wire should be hot with the key
The GPR is working, I checked it with a multimeter last night. Checked all the fuses under the hood nd dash. I realized last night that my WTS light doesn't come on, I'm almost positive that it did the day before. None of my gauges are working either. no tack or oil or anything. I'm thinking camshaft sensor is part of the problem? Still doesn't explain the loss of other stuff on the dash?
I am running out of options, all of the fuses check out. I sent the PCM off to have it tested and fixed (this has taken almost two weeks) only to find out nothing is wrong with the pcm.. Again, my issues are: truck cranks but won't start, no WTS light, no tach or other gauges, the scanner will not read the truck. I've checked the GPR, batteries, fuel pump, all fuses, and PCM. Any suggestions? All I can figure is something chewed on my harness? The truck sat for 4 days while I was out of town and when I returned, these are the issues.
Ok, you need to borrow a good scanner that can read the diesel PIDS. At a bare minimum, to diagnose a no start you need to view ICP PSI, IPR Volt, and check for stored DTCs. You need to have at least 500PSI of ICP pressure for the injectors to fire during cranking. While cranking the IPR voltage should jump from 0.15 to 0.65-85 (depending on the scanner). Check for any codes related to crank position sensor circuit. Report back with these values. Without this info you will be guessing and throwing money away.
Tact
15
12-24-2013 03:56 PM
bl311
09-09-2006 03:15 PM
