Crew Cab Long Bed, how hard is it to drive really?
#31
All the above, plus, you will NO longer make u-turns in those median cuts to enter the driveway on the other side of the highway. You will now make a left 1 block before, and make a series (usually 3) right turns to get turned around. Swing wide, especially right turns.
A dually is even worse because they are wider in the back.
#34
#38
Thanks for all the responses guys! To me it sounds like a CCLB isnt a terrible choice, and i already back into most of my spaces so no issue there. Im used to making wide turns because my 37s rub on the leaf springs so ive lost a decent bit of turning radius too so thats also helping me. Im looking at and driving the CCLB bulletproof 6.0 on saturday, ill see how i feel about it once i drive it. I drove a CCSB 7.3 today and honestly i loved it, perfect length and it was a 4in lift on 35s which i think is perfect height. Only issue is it had 223k miles on a stock auto tranny, which is worrying me and making me unsure on if i should get the truck or not.
#39
#40
#41
#42
I had a 96 F350 CCLB 2wd Dually then upgraded to a 15 F350 CCLB 2wd Dually. The 15 has longer wheelbase and is taller. The 96 was a tow rig the 15 is a tow rig and a daily driver. It took a little getting use to it as i used to drive a sport trac but I park where ever I want and need too. I also try to back in if there is grass or whatever behind me that way it fits better in these short spots.
Visseroth
65
07-29-2009 07:53 AM
pcwirepro
1999 to 2016 Super Duty
09-29-2004 11:04 PM
