Clutch push rod bearing
I have a 96 F150 Manual 4x4. In the last year, I have had to replace the clutch push rod bushing 2. I am using Dorman Help! 14041 kit to do it, but they seem to wear out quickly, in fact the last one I put on today, and it broke within 30 miles. I am not a hard clutcher, I don't let it slap back to engaged, and I dont stomp it to the floor. What is going on? and is there anything I can do to make them last longer?
Sounds like it ran without a bushing for a while and the **** is worn out which would cause the bushing to die again. Might require a new clutch pedal or at least some custom work to create a new **** for which the bushing can be installed. I've also heard of people machining a brass bushing instead of the plastic.
Thank you all for your help! The pin coming from the bracket is worn, and that is what is chewing on the bushings.
I have found a repair for this that includes a heim joint replacement for the bushing/rod joint. Anybody know a good place to get a heim end with a set screw that would work for this? I could get off of ebay, but would like to have it sooner.
Unimog005
03-27-2007 02:24 PM
greatflake
11-21-2003 06:18 PM
