52 F3 Marmon Herrington
Old 01-19-2017, 01:12 AM
mOROTBREATH's Avatar
mOROTBREATH
mOROTBREATH is offline
Originally Posted by truckdog62563
But more time has been spent staring at it and walking around it than cutting, fabricating, welding, and grinding. Stu
Well it makes me feel a whole lot better knowing I'm not the only one...
  #32
Old 01-19-2017, 07:55 AM
Tilleyman's Avatar
Tilleyman
Tilleyman is offline
Welcome to another F3 owner! We're a smaller bunch with bigger trucks!!
That one is a monster with the MH setup, and I've always loved those wheels.
  #33
Old 01-19-2017, 08:46 AM
1952henry's Avatar
1952henry
1952henry is offline
Owen - To my recall the gallery listed Glenn Huff living in Virginia, or in that general area. I didn't realize the Herb Hobi truck we discussed was like this one. I thought it was the yellow shortened F-5 with the Express bed. I guess there's every possibility Herb's was this same truck. Heck, I've hauled each of mine half way across the country. And the two Montana trucks that went to San Antonio have both now resettled in Southern Illinois. Josh described the path his F-2 took from SD to CO then on to SLC. And his F-3 I had archived to a short time FTE member in Big Timber, MT, before it showed up on the lot in Gallatin Gateway waiting for Josh to rescue it.
A couple of those 11 trucks I mentioned that have been lost to follow-up are the ones we've talked about being in the group bought by your Williston neighbors. One I saw sell on eBay from that area just after I bought my ND truck. How many years have we been talking about that group of trucks? Stu
Herb only had it a short time. Like his Power Wagons, he bought it to flip.
Of the Badlands M-Hs, mine is the only one still in ND. The other F3 and the F1 have gone to the east coast as of last year or so.
  #34
Old 01-19-2017, 08:51 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Originally Posted by Tilleyman
.... and I've always loved those wheels.
The 1946/1947 M-H tonners, and 1948 to early 1953 F-3/F-250 M-Hs are the only Fords to ever use the deeply dished Budd 17" locking side ring wheels. There were two widths listed in the M-H manuals, 17" x 4.33" and 17" x 5.00". All that I've recorded are either the Budd #44820 (4.33" Firestone RH design), most commonly found on Studebaker M15s, and the Budd #59340s (5.00" Goodyear LW design) most commonly found on IHC K-5/L150 models.
Interesting to me all the F-2 M-Hs I've seen were fitted with a different wheel than the ones listed in the manuals. All have Budd #47210s, 16" x 5.5", having the Firestone RHP locking side ring rims. Stu
Edit - Owen - wonder if those ND trucks will resurface. I think some I've lost track of have probably left these shores. Hopefully to collections and not to return from overseas as Kias. Stu
  #35
Old 01-19-2017, 09:05 AM
abe's Avatar
abe
abe is offline
One Meadow Green Owner
Received 2,616 Likes on 1,456 Posts
Originally Posted by abe
I think a 53 to 56 COE with a contractors dump would be cool and useful for your work. They have a shorter turning radius.
Would something like one of these be useful for your business?
Here is Old Blue, the 53 F600 my brother used in his concrete business:
  #36
Old 01-19-2017, 10:37 AM
thundersnow70's Avatar
thundersnow70
thundersnow70 is offline
I will also add my welcome. Looks like you have a really solid MH without many missing parts so your adventure will hopefully be painless. As Stu mentioned you have the rear spacers...big bonus. Hopefully your front axle drums are good and the axle shafts are not hurt. The short shaft Josh pictured can be purchased new....ask me how I know. Current application is Ford Excursion front joint. It looks different now but has the same dimensions. Be sure and check the frame for cracks. Front to back. My F3 MH lived a pampered life and has a mint frame and cab. My F2 MH had so many cracks and bad repairs that we reframed 75% of it. Is the oil filter towards the center of the block? I could not tell from the picture. If the oil filter is towards the front it was repowered with a 223.
  #37
Old 01-19-2017, 10:43 AM
thundersnow70
Never mind, I see its a 215! Also a bonus. Looks like your short shaft is laying on the cab floor.
  #38
Old 01-19-2017, 11:04 AM
truckdog62563
Mark makes great points. I mentioned earlier that both he and Josh would notice your rear spacers. Theirs were missing, I believe one of Josh's trucks is still missing its. Rare to an extreme if needed.
The other point is frame fractures. I mentioned earlier the problem with axles fracturing where the long tube is riveted to the differential housing. Overloading also fractures frames. Chuck once told me that the F-2/3s weren't built much heavier than half tons, but were used like F-5s. He said that more 3/4 tons were produced than half tons, but fewer survive today than half tons because of abuse. Chuck says about 200 half tons per year were converted. My archive of 3/4 tons shows 300-400 per year. Of my five F-3/250s, some now only remaining as parts, three have had frame issues to a greater or lesser degree. Stu
  #39
Old 01-19-2017, 06:38 PM
turtleman's Avatar
turtleman
turtleman is offline
Yes.. It sure would LOL
truckdog62563, the number we cant see in the image is;
F3 D2 HM33507
the motor number is 33507 also
I checked a article I read up on and decided to follow that about the voltage issue.. Never fully knowing what a previous owner has or has not done I'll revert to a 6 volt system.. converting to a 12v is a very simple process and if I decide to keep this and build it having a 6v in it is something I'd do anyways.
It started raining here today so I didnt crawl around under the front end to look for the numbers off the HM but another day soaking in cleaner wont hurt it
Edit: the article;
https://www.fillingstation.com/articles/6volt.htm
  #40
Old 01-19-2017, 07:18 PM
truckdog62563
Okay, that I think puts your axle in the 345-350 neighborhood. That would mean your truck was built shortly after my first truck (axle 342) and Mark's F-2 (axle 351). Stu
  #41
Old 01-19-2017, 07:47 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Are you saying your thinking of maybe selling it?
Or maybe a trade for a 53 cabover with running/driving flathead v8 Marmon Herrington ? Of course we would have to convince a 12 year old...
  #42
Old 01-19-2017, 08:08 PM
truckdog62563
This could get interesting! Stu
  #43
Old 01-19-2017, 08:57 PM
turtleman's Avatar
turtleman
OH MY!
  #44
Old 01-26-2017, 08:50 AM
truckdog62563
I'm gonna (maybe selfishly) bump this back to the top in hopes that Turtleman stays around, and posts his axle number. It'd also be good to see some pics of the truck's underside to see what condition it's in. Stu
  #45
Old 01-26-2017, 12:35 PM
jmadsen's Avatar
jmadsen
jmadsen is offline
Turtleman, hope I didnt offend you. As most of the guys on here know i'm mostly full of hot air and engage mouth before engaging brain...
Anyway. We would all love to see more pictures as you progress along with hopefully getting it moving under its own power.
Also as a side note there is a guy named John. John's f100's or johnnys f100s or johnnys junk? Maybe its on facebook? But he is somewhere near Phoenix (queen creek maybe) and seems to always have a few cabover project trucks if your thinking of a cabover project?
Cheers
Josh
Quick Reply: 52 F3 Marmon Herrington
