Starter Relay clicking
Sounds like a bad ground connection somewhere. Especially if you got a good battery and the solenoid clicks fast. You can check the starter connection by bumping the "s" terminal of the solenoid with 12v. Most likely it's your negative battery cable connection though. Try cleaning the battery terminal and negative cable.
Are you sure the starter itself is OK?
RE the negative battery cable, see where it goes from the battery. If it goes to the block, then you need a smaller cable to run from the block to the cab.
If the negative battery cable runs to the fenderwell, then you need a large (thick) cable running from that fenderwell (hopefully from the same stud) to the block.
gaffmedic
08-13-2007 06:48 PM
rrisner
04-17-2002 02:09 AM
