Evaporator
Old 01-15-2017, 08:37 PM
mrpotatohead's Avatar
mrpotatohead
mrpotatohead is offline
Evaporator
Gentlemen, looking for a C8TZ-19860-C evaporator for factory installed a.c. on a 69 f-250. The loser that tried to remove the a.c. assembly on this truck decided to saw through the evaporator lines in hopes this would help the case drop down. He should have tried the two bolts on the firewall first.
Old 01-16-2017, 01:05 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is offline
C8TZ19860C replaced C8TZ19860A. They were the correct numbers for 68/72 Bumps with factory integral air. None on any of the locators I use. None on evilbay.
If it is still good except for the nipples, I would investigate local Automotive A/C companies, radiator shops, or welding companies to find someone who can aluminum weld nipples back on. Or try contacting https://originalair.com/restoration-ford-evaporators. Maybe they can help.
Old 01-16-2017, 01:31 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Factory installed integral A/C evaporator shown as 19860 in pic:
Old 01-16-2017, 11:59 PM
GaryKip's Avatar
GaryKip
GaryKip is offline
Another case of "You can't fix stupid!"
Old 01-17-2017, 06:23 AM
mrpotatohead
Not only did this brain surgeon cut the evap pipes but he also cut the freon lines and broke the case by pulling down on it rather than removing the last two mounting bolts on the firewall.
tazerproof
17
12-31-2016 11:27 AM
gbakman
22
10-11-2016 05:39 PM
ronspolv
11-23-2015 07:02 AM
77 ford shortbed
06-06-2008 03:51 PM
ryanstruck
12-10-2001 07:12 AM
Quick Reply: Evaporator
