3psi, 99 f350 with van turbo, ebpv delete
Hello. I bought a 99 f350 truck. it has a van turbo and exhaust back pressure delete. The truck wont make more than 3 PSI of boost. Ive got a p1690 wastegate actuator circuit code. unplugging the waste actuator does nothing. With the van turbo, is the actuator required? Is this code stopping the ecu from fueling and creating boost? I did a cylinder balance test, and cylinder 8 failed. Is a single injector not quite balanced enough to make it not boost past 3 psi? The turbo appears brand new (previous owner said it was), charge pipes hold pressure (tested), EBP Sensor tube is clean (shows up to 24 psi). I tested the wastegate actuator, OnDemand5 says if its over 50 ohms, its bad and replace it. its 69.5 ohms. Again, i dont want to replace it if i dont have to, as its not being used (no wastegate on van turbo), but if the ecu is preventing it from spooling because of the solenoid, ill change it.
Originally Posted by Rikster-7700
Have you checked the up pipes for leaks? How did you test the CAC system for leaks? You should definitely be making over 3lbs of boost......
I would pop the intake tube off the turbo to look at the blades and check for rotation with no in-out movement. I would also have a good look at the EBP reading when you get the low boost. Do you drive the truck long enough to get the Engine OIl Temperature over 140 degrees F? Do you hear a hissing sound as you drive? Do you see scads of soot out the pipe? Is this 3 PSI boost max with your right foot pulling a Fred Flintstone?
I really appreciate the help. i hope the additional information ive given you can help lead you, lead me into a direction to get this thing sorted out.
I disconnected the down pipe from the turbo and used a mirror to view the other side of the turbo. Though there is some soot, the blades appear as new, and don't have any pitting. I didn't ensure that it spun, but seeing as it is making some boost, though not enough, that the shaft is intact. This problem really is a pain.
If you still have the ebpv unplug it. Your back pressure is incredibly low. Is there freeplay in the gate actuator rod?
Plug the red line going to the waste gate actuator, safety wire the actuator shut and report back.(shut is the rod pulled towards the driver side)
edit it I just remembered it's a van turbo...
howevrr er that being said based upon drive pressure I'd ber the max you would see is around 7psi. You should get up near 40 psi of drive pressure
Your readings in the driveway won't work for us.
Here's what I'm wondering: What is the Turbo Pressure Delta at WOT on a steep uphill grade (to make the WOT longer)? The "delta" is the EBP (drive pressure on turbo) minus the MAP (not the boost). EBP and MAP are both "absolute" pressure (pressure above the vacuum of space), so they both include atmospheric pressure.
On your opening post, I believe, others here can confirm or correct me, that #8 injector fail on CCT is typical due to it's location at the end of the fuel line.
What are you measuring your boost with? Are you sure that you don't have a kinked or plugged line? Since you can perform a boost leak test what happens when you set that leak tester up and read your boost?
And do you have an EGT gauge? If so what's it doing?
I've heard that about the #8 failure too, but I wanted to include as much information as I could.
boost is being read by a matco scan tool, as well as a aeromotive boost gauge. The boost gauge is connected in line with a t with the red line between the factory boost controller and intake manifold. I replaced the hose between the MAP and the intake as it had some cracking. Because of the location of the map, it wouldn't read the charge pipe boost pressure when I'm testing. I did on the other hand use a blow gun lightly on the line going to the boost gauge and tested it with that.
no EGT gauge, unfortunately.
I appreciate the input. Hopefully we can figure this thing out.
Post a picture of the turbo. If its new is it a truly new unit, OE? Reman? Manufacturer if reman? I had a spare van turbo out in the shop and it had a waste gate actuator on it. Mind
