Crossmember removal?
Old 01-09-2017, 06:59 PM
tzavaleta's Avatar
tzavaleta
tzavaleta is offline
Excited to be finally re-assembling the '56. Today was a major milestone as I put the crossmeber back in (shortened for AOD). However it wasn't until after I had the unjoints snugged and greased that I saw how close it runs to the crossmeber that's towards the back of the cab. (Face palm).
Can I just cut out that crossmenber? I know it's a long shot someone will say yes but here's for hoping. Otherwise I'll just do a mini-c-notch on it.
Wider view
Old 01-09-2017, 07:04 PM
seaves46's Avatar
seaves46
seaves46 is offline
Can you change your rubber transmission mount for a shorter one ?
That one seems to sit quite high .
Old 01-09-2017, 07:37 PM
tzavaleta's Avatar
tzavaleta
Rubber mount
I had thought about too but I set up the motor mounts and pinion angle while using that mount.
How much clearance is enough? I wonder if a shorter trans bushing would get me there.
Old 01-09-2017, 08:07 PM
schoo's Avatar
schoo
schoo is offline
Bumped the other thread to get more info
Old 01-10-2017, 10:41 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
Is that at ride height? if so I would notch the crossmember to get a few inches clearance. The amount of clearance you need depends on how much suspension travel you have. I set mine up assuming the rear axle can hit the rear bump stops.
Old 01-10-2017, 09:03 PM
tzavaleta's Avatar
tzavaleta
Notching
schoo, thanks for bumping. I need to update that thread since I've made a ton of progress.
Droptop, I agree all things equal notching is probably the best idea. Out with the plasma...
First step. Cutting a notch. Now I'll make an insert to strengthen the notch I'll likely use 1/8 plate.
Old 01-22-2017, 11:24 PM
tzavaleta's Avatar
tzavaleta
Updates notching the crossmeber.
Cleaned up notch
Cardboard template
Spot welded mock up
Test fit
Old 01-23-2017, 08:31 AM
Jules The Great's Avatar
Jules The Great
Jules The Great is offline
Is that even an original cross member? Looks to be welded to the frame vs riveted on. Too late now but you could have maybe just turned it upside down?
Old 01-23-2017, 08:37 AM
tzavaleta's Avatar
tzavaleta
It's riveted. I think just the dirt makes it look solid. Need to clean that.
Old 01-23-2017, 08:47 AM
Jules The Great
Ok, I don't remember if my 55 has that one?
What is the transmission mount crossmember? Did you get that from a newer truck or is that original?
Old 01-23-2017, 08:52 AM
tzavaleta's Avatar
tzavaleta
Crossmember is definitely not original. It was on the truck when I bought it (had a C4). I had to move it back for the AOD. It's only got one bolt on each side which I'm hoping won't be a problem.
Old 01-23-2017, 09:56 AM
Jules The Great
That should be fine, I have a crossmember from a 1970's Ford truck and it also has only one bolt on each side!
Old 01-23-2017, 10:57 AM
tzavaleta's Avatar
tzavaleta
That's great to hear, one less thing to worry about.
Old 02-16-2017, 04:48 PM
tzavaleta's Avatar
tzavaleta
All done
Old 02-16-2017, 05:26 PM
pbsdaddy's Avatar
pbsdaddy
pbsdaddy is offline
Nice job. But I think I would weld that upper gap closed. There is no sense in giving rust a place to start.
Quick Reply: Crossmember removal?
