Underhood air deflector- 6 cylinder
Hood deflector
The one I got from Roy appears to be for a v8. We couldn't find the part number but measurement wise it appears to be for a v8.
I have a Champion radiator and the part of the deflector that fits around the radiator is to small. So, it appears I may have to modify it anyway.
Going to continue to look for a 6 cyl deflector but may take Dave's approach and cut the v8 one down to work in the 6 cylinder position.
I am not in a hurry so will take my time.
Thanks to all.
Dan
Thanks to all.
Dan
I believe, just from a few rough mesurements, that the v8 deflector will hit the upper radiator hose... if I can't locate one by the time I am ready to put the hood on, I may attempt fabricating one from sheet metal, or it may be easier to just notch the v8 deflector around the hose...
But I would rather have one that is a factory piece.
As Firstrider suggested, I will spend some time in the boneyards here pretty soon...
-Bear
-Bear
One reason to change over to a six cylinder deflector is that the radiator can be moved forward to give more room for a modern power plant.
I looked for years for one. I had a flathead eight that went south after a flood. It was replaced with a 351W.
I moved the radiator forward into the six cyl position. Had to remove deflector because it would then hit the top of the radiator.
Now that I found a six cyl deflector it clears great. Will post some photo's later
barryjdi
11-24-2014 10:32 PM
