I'm needing a 6 cylinder air deflector for a '51... does anybody repop these, or is there anyone out there that has one in decent condition that they would sell?
Thanks- Bear
Do you mean the one that covers the front of the exhaust manifold? P/n 7HW9437 "Baffle assy. manifold air". Used on F-3 parcel delivery, F-5 and F-6 COE's 1948 - 1951. Used with both "H" and "M" engines. P/n 8HA9437 "Baffle assy. manifold air", used on everything else '48 - '51 except F-7, F-8.(From my old Ford book).
You can also contact Chuck's Trucks, highly recommended.
Out of curiosity, why would the six cyl. version be different from the V-8 version since it is located in front of the radiator, and all other parts being equal?
The width of the hood tapers towards the nose. The entire radiator position including the air deflector is a couple inches farther forward on the 6 cyl. trucks and the matching deflector is narrower to fit.
Dan I have one 4 you it could be for a V8 I could not see any difference between them so it could be the 6 I will put the two side by side and see
[I]I think this from a 6[/I
Just measured the V8 is longer that pic is not a 6 but a v8
I have one for you if the shipping from CA isn't too bad. My hood got pretty wrecked by mice (nests = pee = rust) but the deflector is fine. Just PM me and I'll try to get you going.
The six cylinder air deflectors are stamped with a letter H on one side on the part that fits along side the radiator. The V8 deflector is stamped with a letter R in the same place.
Mark
