Rear Driveshaft
"Larger" in what respect?
Bearing cap diameter or width across the U-Joint???
Many Fords use a "Big Cap" rear universal that is the same cross with 4 same size trunions, but two caps are 1-1/16" OD while two others are larger at 1-1/8" OD which means thicker cap material. They did it because the thicker caps can better resist ham fisted mechanics over tightening the two U-bolts that secure the caps in the yoke on the rear axle.
U-Joint series identification
I have a 1997 Gold Wing GL1500 that was converted to a trike with Lehman GTL kit and it uses a shortened Ford 7.5 integral carrier rear axle and the rear U-joint is a 1310BC U-joint .... I use a Moog 430 in it.
I forget whether my '77 F150 uses a BC joint or not?
.... Starting in the early 1960's Ford started using a pinion yoke that was just 1/16 bigger. This means only the 2 caps that go in the pinion yoke are .062 larger than all the others. Only those 2 caps.
... etc ...
... etc ...
CountryBumkin
16
06-05-2017 02:30 PM
woodtrucker
10-27-2013 08:18 AM
Snicko4630
01-14-2000 09:02 AM
