Anyone noticed moonroof or other interior leaks?
Hey guys, had my truck for two months, and within a few weeks I started to notice a musty smell in the cab. I've got a 17 CC 250 short bed with lariat ultimate. I immediately checked for leaks along the moonroof and did not find any wet spots, and don't see any staining. The smell has not gone away, and actually grown a bit stronger. I do believe it is the smell of mold or mildew, almost like I left a pile of wet towels in the truck for a few weeks. I am approaching 5000 miles, and was going to have the dealer check it out when I send it in for an oil change. Just thought I'd check to see if any of you noticed this smell, or had any trouble with leaks?
From what I understand, the moon roof secondary drains from the inside pillars near the front windshield,...don't quote me on this, what happened to me was one of my clearance light caps on my 2011 f250 was missing and water was running down the passenger pillar when raining. Maybe a drain is plugged up?
Maybe this might help.
I am in south eastern Virginia. My f150 never had an issue, and the first few years were spent in Michigan with it. Nothing spilled as far as I know. And I can smell it as soon as I open the door to get in. I'll have to give the pillars a thorough check in the am, and get up close to carpets just in case I missed something (don't think it is the carpet).
Left my rear doors open on mine as I drove thru the car wash, not a drop came in. The running boards open when the doors open and they are independent, so if I get out on the drivers side only the drivers side running boards open. To wash them I opened the 2 rear doors just enough to open the running boards and I washed them at the DYI bug wash lane, got to talking to someone about the news SD and then forgetting to close the doors I drove thru the car wash. Pulled over as soon as I got out of car wash and inspected, not a drop, not a wet area anywhere...
Mine has been washed twice, once for dealer prep. The second time, after my first big trip, in a touch less car wash. Huge amounts of water jets from top, sides, front and back. Undercarriage too on the way in. I had the sunshade open all the way to see what hapened. No leaks that I could detect, so far so good. My 2005 had a sunroof and it had four drains in each corner. Never did get a leak or issue all the many times washed in 12 years. I have not looked to see but I am sure there are four corner drains on this one. Main thing you watch for is if your under trees and junk all the time, those drains must be cleaned by getting up there with the sunroof open and pulling out any pine needles, tree junk, if the low corner doesn't flow water away, the drip tray around the sunroof will over flow on an uneven surface. I had this happen on a Celica GTS long time ago, and on my old Toyota extra ab sunroof.
on
