Suddenly dead battery
#33
Already replaced the starter. As sarcastic as your comment may be. Cables have no apparent frays or breaks. Everything is tight. it starts fine sometimes and then just doesn't even try. Possibly negative cable ground to frame?
#34
#35
Checking the ground cable to block connection is always a good idea if you are under the truck to deal with starter issues.
The 'flag' connection to the frame at the crossmember is not likely to affect the starter.
#36
Not even a click?
The fender mounted relay grounds through its mounting ears.
Is the relay tight? And the little red/blue wire firmly on the 'S' stud?
You could try taking it off and sanding a bit of paint from behind it to ensure that the relay is making ground.
#38
The problem started as symptomatic of a bad starter. Replaced with a reman. Maybe not a good idea. The reman starter has been starting but I do not go far from home because I don't want to get stuck. But I have to get gas so I'll have to risk it.
Local mechanic said that the reman starter may have an issue of its own because the truck will start and then all the sudden won't until you remove the starter and then put it back on.
#39
#40
Had a NAPA rebuilt power window motor that right out of the box would not operate 1-in-5 attempts.
If you run into a situation of lights "on" but no "click" at solenoid, do not discount the possibility that your ignition switch (that is rod-activated by your ignition lock), may have a consistent, reliable, "run contact make", but an inconsistent "start contact make".
EDIT: Later saw your next post. In the electrical world, do NOT rely on anything that looks like there has been any part burned.
#41
#44
