F350 hood rock/bug deflector
So I'll start by saying that I am EXTREMELY excited to pick up my new-to-me truck tomorrow morning. I'm switching sub forums here, as my wife has taken the 2014 Expedition Limited over, and I'm stepping into a 2015 F350 Lariat FX4 Crew Cab diesel. Tuxedo Black/Black Leather. I'm am so pumped...
Anyway, I'm outfitting it with a hard folding tonneau cover as well as a hood deflector to help with rocks/chipping. On the hood deflector, I like the way the OEM ford one installed, it was just existing holes and plugs. No adhesive tape or hood clips required. I'd love to find one for the 350 hood that goes in the same way.
So far I've looked at the following:
Ford OEM - uses tape
AVS - uses tape and clips
EGR - uses clips and screws in factory holes (the leading candidate)
Lund - uses tape
Stampede - uses tape
Weathertech - some complaints over install quality/alignment so disregarded
So the EGR Aerowrap or SuperGuard are in the lead, as they at least are the only ones I can find that don't use any tape, but still have a clip on each side.
I'm looking for a nice countoured guard that is smoked. Any ideas on brands or models I should look at?
Thanks.
Lund - uses tape
Thanks.
Even though you're against the 2 sided tape models, I'm on my second Aeroskin. Left the first one on the truck I traded because it was not coming off without damaging it.
I've also had the type that you mention that push into the existing holes in the hood. No problems with those either, but I wanted something that lays down as much as possible.
I've had good luck buying from realtruck.com and autoanything.com
I've got no problems with Aeroskin. Which I guess I forgot to mention is made by Lund. Some shields will also make some noise with window vent visors also. Just another thing to consider if you have them or plan on getting them.
Thanks. No plans for window vents, just thinking about the hood deflector. Picked the truck up yesterday and love it, but not sure of adding anything to that front end. It's nicely sealed with the rubber gasket now. Here's a pic and I like the clean lines. Just wish I could see some good real world pictures of various deflectors installed.
I let the last one go when I traded the truck because I didn't see any easy way it was coming off without damaging the deflector.
Thought I would return with images of the EGR Superguard Hood Shield installed in case it helps someone in their buying decision. If you are looking for a very low profile guard this one is probably not for you. I wanted something that stood high enough to keep the bugs and rocks off the windshield. Time will tell how good it does this spring when the big bugs are in season.
I couldn't decide on which model, but did decide on EGR. I talked to them about the SuperGuard and AeroWrap. They said they are very similar but the AeroWrap wasn't as wide. I ordered both since pictures of the units were limited. Seems like the same pics are used online for both products.
dirthawg, can you see it when sitting in the drivers seat, and could you post one pic straight on from the front of the truck?
