Well What turbo should I go with
#61
#71
#72
Make sure the cap hasn't failed. It should release pressure above 16 psi. If the cap is bad it will push gaskets out. Test your cap.
#73
If you wanted to check and see if there is a blow head gasket I think and easiest way to do it would be to purchase a spare cap, or new cap and drill and tap it with a barb fitting, route that barb fitting with some tubing or hose into a glass filled with water. Once it's up to temperature there should be no bubbles being forced through that hose and bubbling up through the water. If there were bubbles that would indicate gas entering the cooling system which willl all be returned to the expansion tank eventually and vented through your hose
I have zero leaks on my powerstroke and my radiator hose doesn't get extremely hard, I doubt it should be anywhere near 15psi at temp because the air in the expansion tank acts as a bladder tank and compresses. So if say the cooling system is 10 gallons and the coolant expands 5% that's a half gallon of space taken up by expansion. There's say 1 gallon of air space in the expansion tank. That compresses to a 1/2 gallon of air and compressing air to half then your tank pressure would be 2 atmospheres or around 14.6 psi i believe. I think the expansion of 50% ethylene is less than 1% figuring in a 200 degree change in temperature from hot to cold. So the pressure should be very low.
On the idi engines there is no expansion tank, they get rock hard because the coolant expands, doesn't compress because it's a liquid so it meets the 13psi cap pressure then goes into the overflow tank. When it it cools coolant contracts and sucks back through the radiator cap.
#74
#75
