Question about using 4X4 in the snow.
So I live in Southern California and have driven in the snow before but only with two wheel drive trucks. My current 2016 is a 4X4, I am taking the family on a trip to the mountains for some NYE snow fun. My question is when the roads go from snow covered to asphalt back to snow covered etc.. How should I handle this? Take it out of 4X4 when I enter the asphalt back to 4X4 on snow?
Sounds like a stupid question, but the senario is traveling say 30-40 and the roads are constantly changing what do you guys do? Don't want to do any damage driving in 4X4 on dry pavement in between areas of snow. Stopping every time to change doesn't sound like fun. I don't want to be crusing along in 2 wheel and suddenly hit snow and ice with no time to engage 4X4.
I know somebody is out there laughing, but us Socal people don't drive in snow that often.
You want to shift out of 4WD on dry pavement. If you have ESOF shifting out of 4WD will unlock the front hubs (if they are in auto) and disengage the transfer case. Shift back into 4WD in snow. I don't recall if there is a maximum speed at which you can shift into 4WD on the fly, but I would keep it at a slow to moderate speed when shifting into 4WD.
If you have manual hubs (or auto/manual hubs set to manual) you still want to shift out of 4WD which will only disengage the transfer case, the front hubs will stay locked unless you get out and unlock them each time. In this situation I would leave the hubs locked and shift into and out of 4WD as needed. Once you are completely clear of snow shift out of 4WD and then unlock the hubs.
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
To the OP, I probably wouldn't even be using 4 wheel drive in the situation you are describing unless it is heavy snow but that is an experienced winter driver speaking.
I would only put it in 4wd if you need it, not just because there's snow on the road. If the snow is deep or heavy and causing you to lose traction or just feels squirrelly, then by all means use the 4wd.
There are many times when I'm on a road that goes back and forth between bare pavement snd snow covered (mainly due to blowing snow). As long as I'm comfortable in 2wd, I leave it there.
As has been stated, you probably don't need 4x4 just because there is a slight amount of snow on the otherwise cleared interstate.
Going 45 and hitting an ice patch on a curve - whether you are in 4x4 or not won't matter you'll probably loose control and skid either way. Just keep an eye on folks ahead for signs of trouble and remember you want to arrive alive.
