Does a crown vic suspension lower the ride height?
What is the weight difference between car and truck with the CV swap?
Dave - - -
Thanks...I don't want to lower the truck because of all the trim and big camper special mirrors, just don't think it would look right. Also don't want a mushy ride, so I wonder if those Heidts kits would be worth the money and keep the stock ride height.
Shop By Application - HEIDTS
Curb weight of a 2003-up CV is 4,057 lbs. P71 (police interceptor) CV springs are rated for 710#. P73 and P74 (civilian models) CV front springs are rated for 440#.
If you don't want to lower the truck, a CV swap probably isn't for you. --Heidts front suspension will lower the truck as well, even without the drop spindles.
Nothing wrong with the twin I beam suspension when nothing is worn out. I was just talking to Randle about this the other day. I do believe he does have the Dream Beams, but he loves the way his rides. So does Tomahawk. He's ridden in Randles truck. The trick is Randle replaced all suspension and steering parts when he built his rig. Nothing is loose or worn.
What's the difference with the Dream Beams? Only draw back I have to the Twin I-Beam setup is when the truck is going over 80 mph...kind of want to take the 460 to the salt flats, but not with Twin I-Beams. My front suspension is all good, but are there polyurethane bushing available. Maybe that and some fancy Fox shocks might help.
Polyurethane I-beam and radius arm bushings, a set of Moog CC808 progressive rate coil springs, new kingpins/bushings, new tie rods/steering linkage, a decent set of shocks and the addition of a '75-'79 front swaybar (if you have Dentside front discs/suspension) will make a big improvement to the stopping and handling of the truck with stock I-beams.
These are the things I installed on my '69 F100. It handles, rides and stops much better now.
Just my opinion and everybody's got one. But something about lowering the front spring rates of a "truck" really turns me off. Plus lowering the rear so that you can no longer even haul a few bags of concrete without damage?
Something tells me that the CV front end swap is only going to be a "fad" that fades over time. Or in return, makes all unmolested F100's that much more valuable in the future. At least the dream beams is easily reversible. Not much so the rear frame modifications though.
Heck, even the lug nut rate of a 5 on 4.5" limits the wheel load capacities available. I see absolutely nothing good with a CV swap unless I become unable to step into my truck as I age.
Thanks!
When you get into the 'bolt-on' front disc brake kits, you're going to end up with a mix of parts from other auto manufacturers. Fine if you don't mind that. I just prefer to keep it all Ford parts from one model year for simplicity of replacement when something does wears out.
This is the setup on my truck.
