Bright'n ur up
Here is a quick run-down on what to look for in terms of temperature:
- 8K is getting into the purple range and most avoid it for places where they want to actually see anything.
- 6K gives a blue-ish tint to the light where some like it but most find it annoying.
- 5K gives a nice sharp white and is good for markers (license, etc) and the interior.
- 2,700 - 3K is closer to the incandescent bulb and has more yellow / brown to it.
Aside, for lighting inside the house (120v) keeping the LED temperature in the 2,700 - 3K range is desirable for most of the living spaces.
My experience with cheaper LED bulbs is that it not necessarily better, especially for dual-element bulbs (ex: blinker / marker combination. Bulb styles 1157, 3157, etc) as the difference from low to high is minimal which makes it difficult to tell when the blinkers are 'On' as opposed to just the marker.
For dual element LED's, take a look at v-leds.com. They are expensive and you get what you pay for as the products and customer support are great.
Last item, if putting the LED in back of a colored lens, use the same color LED (ex: amber LED in back of an amber lens). Avoid using a white LED in back of a colored lens as it results in color shift (yellow will appear canary and red will appear pink).
Consider not shopping based off the 'description' (ex: warm, bright, etc . . .) as it is highly subjective. Go with the 'temperature' as listed in Kelvin or K. Personally, I avoid any seller that only states the color by 'description' and not 'temperature'.
here is the video, I have amber in the front (clear lens) and two red in the rear (did not show as they do not flash)
You can go to www.superbrightleds.com and put in your vehicle info to get a list for whatever vehicle. I will say that if you have a car with a CANBUS (Audi, VW, etc.) then you'll need to get ones designed for that specific vehicle. I have used "Luyed" brand LEDs (bought from Amazon) and am extremely pleased with the light output and quality of them.
Got ur shining, but having a heart attack when wanting to turn. Them arrows gunna pop out of the cluster. Found out that the relay is located inside the dash, haha.. Wonderful! Will have to wait for the weekend to replace.. Playtimes' over til then....BTW, got 2-rear led flush mounts almost ready for install. Will start new thread on them 😉
