New project truck possibility
EDIT: new truck listed
Hi all, I'm on the hunt for my next bump. FOund this one today but it's 4.5 hours from my house. If I make that drive I would need to buy it. Asked the guy for more pics. Inside, outside, engine bay and cab mounts. Would you drive almost 5 hours through the mountains for this?
https://westslope.craigslist.org/cto/5917761497.html
Is there a place to check numbers to see if they match? Not sure how long this guy has owned it and may not have the history. But like you said, if it's in nice shape, what does it matter.
Decoding Your 1971 Ford Truck VIN - FORDification.com
Location of VIN on frame.
Finding Your Truck's VIN - FORDification.com
The VIN is stamped on the Warranty Plate, riveted to the left door face below the latch. Printed on the Certification Label, glued to the B pillar below the striker plate.
But compare these VIN's with the hidden frame VIN to see if they match.
The 4V manifold isn't original and on sale day, 360's magically become 390's!
The cargo lamp was an option, the body, lens and bezel are the same as 1964/65 Thunderbird backup lamps.
The grille, as previously mentioned, isn't original, appears to be from a 1967.
Neither one of my Rangers have a Cargo Light. I'm going to have to cut the hole to put my spare in.
Looks like a woodgrain XLT horn pad. Curious if the red interior was added like the 67 grille at one time. Not that I have a problem with that. If that's a 4V, it's gotta be an old Autolite Model 4100.
Attachment 210589
Attachment 210589
Serendipity.
Can't say I'm too concerned with that. In fact I am in the process of selling an all original 70 ranger xlt. The only thing I was looking for was a manual, and this isn't it, but could be a good candidate for a manual swap. Especially since the steering column needs to be replaced anyway. I may go check it out tomorrow. Didn't work out to see it today.
Yeah, 4WD is good to have in CO - about 4 days out of the year haha. I have a 4runner and old suburban for that. This won't be a daily so 2WD is just fine for my purposes. If I come across a nice 4WD truck I won't not buy it, but it's not a must have.
1970/72 Ranger/Ranger XLT have 3 5/8" wide upper side mouldings. Rangers have black painted inserts, XLT's have walnut wood grained (decal) inserts.
1971/72 Ranger XLT's have a walnut wood grained finish horn pad, all others have a black camera case finished horn pad.
I seem to recall that 1970/72 Ranger XLT's also have misc dash parts that are wood grained, XLT's also have unique door trim panels.
These are the hole dimensions for the cargo light.
The centerline location of the screw holes are 1-1/2" down from the seam on the back of the cab and 25-3/4" from the far side of the spot weld on the edge of the cab seam, as located by the green pieces of tape on the back of my truck's cab.
.....and whether you're installing a cargo light or already have one, it can also double as a high-mount 3rd brake light to help reduce the chances of some inattentive person from running up your tail pipe.
