Fuses
Sorry I don't have time to help look for you right now but,,, do a search for
"year 2000 ford cut away builders layout electrical wiring" you might also add "fuse" to the end of that search
also try the "immages"
I searched a few minutes but have to go take care of some business for now.. Hopefully you will find what you need..
Also try this, it is for a E450,,, you didn't say which model you have
Ford E-Series E-450 E450 (1995 – 2014) – fuse box diagram
http://www.autogenius.info/ford-e-se...e-box-diagram/
Ford E-Series E-150 E150 E 150 (1998 – 2001) – fuse box diagram
Year of production: 1998, 1999, 2000, 2001
Ford E-Series E-150 E150 E 150 (1998 ? 2001) ? fuse box diagram | Auto Genius
Ford E-Series E-350 E350 E 350 (1997) – fuse box diagram
Year of production: 1997
Ford E-Series E-350 E350 (1997) ? fuse box diagram | Auto Genius
Both of the above links show the Courtesy lamp to be #4
The first post I made, the link shows it to be #8
Some more
Also shows to be #8
Ford E-Series E-250 E250 (1995 – 2014) – fuse box diagram
Year of production: 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2009, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014
And finally,,, I guess yo checked the bulb first?
Ford E-Series E-150 Fourth Generation (from 1992 ) – bulb specification
Year of production: 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016
http://www.autogenius.info/ford-e-se...specification/
Some more
Also shows to be #8
I've done this and keep copies of the fuse & relay box layouts as well as the legend for what each fuse protects.
All E-Series at least from '97 to end-of-life 2013 full bodied vans have the two fuse/relay boxes. One under the hood is known as "Battery Junction Box", the inside under the dash is called "Central Junction Box".
The following users liked this post:
Common courtesy and appreciation for help provided here and just about every other part of life has long since disappeared. I mean if its free that means its essentially worthless and doesn't deserve such treatment.
That sort of thing has me more and more simply ignoring peoples requests--over time I've developed a sixth sense towards those who want want want and rarely if ever return the favor.
Wolfowner
01-10-2008 07:25 AM
