full synthetic vs part vs conv.
Old 12-06-2016, 12:11 PM
Four.on.the.floor's Avatar
Four.on.the.floor
Four.on.the.floor is offline
I have a 1995 f150 with a 5.0.
I used to run castrol gtx part synthetic 10w-30 and had no problems ever. I recently installed a mech. Oil pressure gauge and was wondering one day (when it was cold outside) how quicker is a full synthetic to reach the full PSI pressure that my truck gets to. I do not know what is acceptable but it seemed like the oil was taking a little while to build to 50psi.
So I went to a castol edge full synthetic and it made a huge difference in the time it takes for the oil to become pressurized to 50psi. It probably decreased by 70%
Old 12-06-2016, 04:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,363 Likes on 1,076 Posts
Faster couldn't hurt but I always used Motorcraft oil and filter in my '87 U150 302 and got 295K miles on the engine before it spun a bearing. My Taurus has 335K on the original engine and is spotless inside- no sludge buildup at all. They extra cost of full synthetic isn't worth it for me.
Old 12-07-2016, 08:25 AM
Four.on.the.floor
Do you have to add a quart between oil changes ?
Old 12-07-2016, 07:34 PM
My4Fordtrucks
I do on the car. Oil pan leaks a bit.
Old 12-08-2016, 12:24 AM
arse_sidewards's Avatar
arse_sidewards
arse_sidewards is offline
I use the cheapest oil, Motorcraft filters and try not to drive too aggressively until it's warmed up.
As long as you have oil in it and change it on time it shouldn't really matter. Going synthetic or not isn't going to undo the last 20yr of wear and tear.
Mechanical gauges will always lag behind the engine because they're at the end of a long skinny tube that's almost certainly got a fitting that restricts it where it plugs into the block. Thinner oil = less lag.
Old 12-08-2016, 09:25 AM
bbf385's Avatar
bbf385
bbf385 is offline
I try to stick with an oil that has a higher ZDDP level (Valvoline vr1 or lately I've been using Quaker State defy high mileage.)
Amsoil Z-rod is supposed to be good as well but I have never seen it for sale.
Old 12-08-2016, 10:50 PM
Four.on.the.floor
Why do you want zinc in your oil so much? Do you have a flat tappet cam
Old 12-08-2016, 11:45 PM
ChRoNo16's Avatar
ChRoNo16
ChRoNo16 is offline
10w30 Royal Purple here with a mobil 1 filter.
1996 f150 with a 5.0 2wd 196xxx miles just for compare
ddeflyer
03-24-2015 12:39 AM
Alwims
Modular V10 (6.8l)
17
08-03-2014 11:38 AM
jman724
Oil & Lubrication
32
01-17-2006 09:00 AM
StorminTexan
3.8 & 4.2L V6
19
12-06-2004 02:06 PM
MENESLIS
1997-2006 Expedition & Navigator
01-26-2004 04:49 PM
Quick Reply: full synthetic vs part vs conv.
