Dash Vibration
on
Dash Vibration
Any of you guys hear a vibration in your dash when stopped and in gear? Sounds like high center, maybe over the gauge cluster. Only in first, with the brakes applied. If I shift to neutral it stops, also if I shift to manual, and into 2nd it also stops. It's not loud, but I can hear it with the stereo off. Stethoscope is next.
on
Hey guys, bringing this back up.
I traced the vibration into the engine compartment, sounds like down next to the motor. Cold weather here has kicked it up, and now I can create the sound in park, not just in 1st gear. Immediately goes away under acceleration.
Power steering pump? Possible? Any other ideas?
Thanks much.
Thanks much.
Thanks much.
Thanks much.
Diesel Engine?
joshfelt
05-01-2008 10:58 PM
