after market AC
after market AC
Some I know the total wrong time of year but it where I am with the project. I am looking at replacement AC\heat options for our 1974 f100 390 it is a non AC Cab and tore down and returned from paint with the dash out I plan to order the march supentine set March Performance - Ford FE : Ultra
I was looking at vintage air and it look to be about the best out there have anyone installed one in a dent or used a different setup. Here is the state of the truck now
Walt:
I'm putting a vintage air unit in my 666 F-250. I am happy so far with the apparent quality, but undergoing restoration, I haven't run it yet. I'm not using the pre-fit set up because I don't like the black abs strip that sits under the dash...I think it looks cheap. So, I am buying the components individually and have run the controls and louvers into the dash instead. What you see in the photo, under the dash is Vintage Air's "mid" size unit.
Hi, I used the vents from the Nostalgic Air because they have ones that look like factory and used Vintage air for the rest of the AC heater. The Nostalgic has a good AC but the heater isn't doesn't work so well. If you look at my build I have pictures https://www.ford-trucks.com/forums/1...-efi-swap.html And Vintage has been around for years and the controls work like new factory vehicles.
Thanks
The piant and body work was about 7500 paint alone was 5000 had it done by a shop in Elk Grove Ca they use Valdpar products it's a black cherry that we teamed a little to make sure it flops on the red side
thanks for all the info I think we go with vintage air unit to get the heat to the floor and the vent from nostalgia air the dash is still out as I need to install the America wire kit
Thanks I will take you up on it. what did you order as far as under the hood. I replacing the radiator with a aluminum, installing a the mark 7 dual fan. So any help on what condenser dryer and plumbing would be great. don't think I am going to use the stock vents especially seeing the photo on this thread and the links.
I also used these ProLine Venturi Louvers (p/n 49212-VUQ), pictured on the left side of the gauge bezel. They look like a little throttle butterflies.
https://www.ford-trucks.com/forums/1...-build-24.html
Continues on the next page too.
My truck is freshly painted. We sanded it down to bare meal and sealed the cab. However, I am putting a crate motor and a 4r70w transmission in it. Paint and body was only 3300 but that's because I did a lot of prep work and had it done by a friend and not a shop. My heater works so I was just going to add the air only kit to my factory heat only truck.
