Moisture in headlights
Along this same lines...has anyone noticed any issues with water in the front camera or it being blurry and fogged up? Just the other day I went to show someone my front camera...and it is totally fogged and blurry.....like water got inside. I washed it, wiped it...still no Bueno. Might have to take it in. Just curious if anyone else has seen the same issue. I'm willing to bet NO...or it would have been on here already. Thanks.
on
on
It seems like a simple seal leak and needs replacement. Shouldn't be a big deal but you never know. I've run through the automatic washer many times and I've watched the tail lights, head lights, and sun roof pretty closely for water. None so far. Have you watched the camera spray washer pop out and spray the lens while viewing with the camera on? If you haven't, just enable the 360 camera view and then spray the windshield washers. The front camera gets sprayed at the same time. Maybe you can see actual water droplets come in at that time?
Gonna revive an old thread here. I just drove through an all out monsoon of rain the past couple days. I too have a bit of moisture at the bottom of both of my headlight lenses.
Anyone else experience this? Bulbs are sealed perfectly. Same amount of moisture on both sides which makes me think this could be normal.
Thank you.
Thank you.
