78 F150 2wd SCab braking issues
Old 11-27-2016, 04:28 PM
Dano78's Avatar
Dano78
Dano78 is offline
I'm at a loss at what is going on with the brakes on my truck. I have a 78 F150 Supercab Shortwide 2wd with a 460 and C6. It won't stop to save its life. Pedal goes practically to the floor and wont lock up a single wheel on a panic stop. I've replaced the maser cyl twice, booster, both rear wheel cyls, front calipers, new shoes/pads all around, hardware in the rear drums, basically everything. Bled and re-bled the system many times over... no air. Have these trucks always had stopping problems? I've owned several pre-'77 Bumps and Dents and never experienced this kind of problem. I've heard the '78-'79 Broncos having similar issues. I also have a '76 F100 SWB with a 460 and C6 that stops on a dime, damn near throwing you out of the seat. Why doesn't my '78 do this? What Am I missing??
Are there differences between the brakes between pre-77 and 78-79 1/2T trucks? Different pedal ratios?
I had also installed disc brakes from a '74 F100 onto my '69 F100 (351W/C4) using the '69 Drum brake booster, but rest of parts from the '74 and it works like a champ!
At a total loss at what's going on with my 78 SCab...
Any and all help greatly appreciated.
Old 11-27-2016, 06:27 PM
ubereal2's Avatar
ubereal2
ubereal2 is offline
Are the rear brakes adjusted properly
They should be adjusted to where they are just barely touching the brake drum. And there is a front, and a back brake shoe, are they in the right place? The brake shoe that has more material on it goes to the rear of the truck.
Old 11-27-2016, 07:44 PM
Dano78's Avatar
Dano78
Dano78 is offline
Oh yeah they are. I had posted about this about a year ago and finally found it to review it. Was trying to repair what was there as i find it hard to believe Ford would sell something with braking this bad.
If i cannot figure this out then i'll have to go for the F350 upgrades suggested on the other post. Just trying to keep the truck as original and correct as possible. Also keeps me from forgetting all the swapped parts for repairs down the road! My memory isn't getting any better!!
rgnprof
15
07-13-2016 07:26 PM
gartlesby
10-24-2015 10:29 PM
burnsum2
03-28-2014 05:55 PM
4RINGS
09-01-2005 08:14 AM
78 crew 4x4 short
03-22-2004 02:50 PM
Quick Reply: 78 F150 2wd SCab braking issues
