1997 ford f250 7.3 powerstroke
Ok I am having a problem with my 7.3 powerstroke it runs rough and dies sometimes. I will start with it has a rough idle and shakes bad the truck also dies sometimes and is hard to get started has no power when it does run. it also smokes a little white. so now with what I have done replaced bad injector changed fuel filter and pump also put new cam sensor in I cleaned the fuel system as well. I put new fuel lines on when I put the pump on.it put new batteries in the truck as well as new valve cover gaskets and I checked the wiring to them I can't find any breaks. I am running out of ideas I need help
To me , it sounds like you have an issue with the electronics that fire the injectors. Whether it is the wiring or the IDM. You replaced the valve cover gaskets, but how about the under valve cover harness? What brand of gaskets were used? Have the outer pigtails to the valve cover gasket ever been changed? If so were the wires soldered together or were but connectors used? Remove the IDM and give it a shake and listen for a water slosh coming from it. If you hear a slosh, you need a different IDM. Do you have someone with a similar truck that you could test your IDM in? Plug your IDM in the other truck to see if the miss?rough idle follows to the other truck.
I've been lucky, I have never had a IDM go bad, and from what I have read, they don't crap out to often. I have had a bad pigtail on the injector harness burn up causing the IDM to shut one bank down to protect itself. Get the truck started, then unplug one connector to the valve cover gasket. If there is no change in how it runs, plug it back in and do another. When you find the one that makes no change. the problem is with that plug/wires. An IDM from a New body style with the 7.3 will work on our trucks, but they are more difficult to get to them, as they are located behind the inner fender liner.
I am also getting oil in the intake I am just wondering if I should get it rebuilt or just sell off the truck and cut my losses. The truck is beautiful no rust and its a 1997 f250 dually extended cab 5 speed I love the truck but don't know if I should bother with it
It does not change when it gets warm it has been running high pressure the whole time I have had the truck I was wondering about this and what do you think I should test first?
^^^^ +1, visual check. And no, it should NOT be that high after EOT reaches 150-160F, no matter how cold the outside/startup temp. Dunno if the oil leak you reported in your other thread is related, but IIRC, the EBPV actuator somehow uses oil hydraulically to operate the valve, so these may be related issues. Looks like you're going down the EBPV-delete road anyway, so this might just be another reason.
