'49 F4 disc brake conversion update
I temporarily added a vacuum reservoir to my truck from a '71 F600 U-Haul truck that I parted out. I was concerned that the factory vacuum pump on the Mercedes diesel wasn't large enough to do the job. When I checked it a couple of months ago, I had about 8" of vacuum at an idle and maybe 15" max at higher RPM. Today I found a line fitting on the pump that I hadn't tightened. Now at an idle it will take the reservoir and vacuum system from 0" to 22" in about 45 seconds. I took the truck for a test drive and the brakes are very good. It will lock up all the wheels and slide to a straight stop on pavement. I am very pleased with the brakes.
Thanks, Mark
Thanks, Mark
Dr. Johnson
13
07-23-2015 08:05 AM
ctann
09-04-2005 08:09 PM
