77 to 82 Tailgate Question
11-16-2016, 03:38 PM
on
Dumb question, but would a 1977 Ranger tailgate fit a 1982 Ford F100? I've found one in darn good shape but wasn't sure if it would work.
11-16-2016, 03:49 PM
I don't know if it make a difference or not but would this be for a flare side or style side truck?
Dave ----
11-16-2016, 04:12 PM
on
Quote:
Originally Posted by
FuzzFace2
Dave ----
Style Side, not flare side..
11-16-2016, 04:32 PM
silar
None of the mounting hardware is the same 1973/79 vs 1980/82.
1980/82 is also different than 1983/86. For one thing, 1980/82's have the latches made as part of the tailgate supports (scissors).
11-16-2016, 05:51 PM
on
NumberDummy
I'm assuming you mean the supports on each side when you lower down the tailgate.
11-16-2016, 06:04 PM
silar
Styleside tailgate supports (some people call 'em scissors) shown as 44400 in pic.
They're the same right/left: 1964/66 F100/250 2WD; 1966 F100 4WD; 1967/79 F100/350.
Notice that the latch (431D76-only the right side is shown) is separate from the support, but on 1980/82's they're a one piece assembly.
The 1983/86 tailgate has separate latches, but use cables instead of the metal supports.
11-16-2016, 06:12 PM
on
Thanks Bill... You are a ridiculous wealth of info! Other than that, would the tailgate work if I could "mod" the latches?
11-16-2016, 06:18 PM
on
Actually I just checked mine, which is an 82, and they are separate also. See the attached pic.
11-16-2016, 06:31 PM
silar
This is not the latch, this is the
striker plate for the latch. 1980/82: The latches are made as part of the supports.
This striker (
E3TZ-99431D54-B replaced
EOTZ-99431D54-A )
is the same: 1980/91 F100/350. 1973/79 are different (see 431B54 in pic in post #6).
Edit applications: 1980/89 F100/350 & 1983/91 Ranger.
Reason: Edited (corrected) the applications.
11-16-2016, 08:06 PM
on
Thanks Bill.. Still a bit confused... So if I was to get the hardware with the 77 tailgate, would that not work?
Please excuse my ignorance! lol!
11-17-2016, 05:45 PM
on
11-18-2016, 03:02 PM
on
NumberDummy
This is not the latch, this is the striker plate for the latch. 1980/82: The latches are made as part of the supports.
These strikers are the same: 1980/91 F100/350. 1973/79 are different (see 431B54 in pic in post #6).
I beg to differ. The 87 tailgate I had on my 84 used a different style striker, more like one you would see on a door.
11-18-2016, 04:48 PM
maytag906
You sure it was a 1987 tailgate and not a 1990 or 1991 tailgate?
1990/91 is different than 1980/89, see my edited (corrected) post #9.
11-18-2016, 05:10 PM
on
"Could" be a 90-91. It was an 87-91 style, owner told me 87.
11-18-2016, 06:07 PM
My '87 has a stud with a torx head very similar to the door striker post.
