Hey ND how bout for a C6 bolted to a 1976 360/390 F250? Hell while im at it, how bout the part# for the power steering return hose ? same truck NO A/C 4wd.....
Same bolts as listed in post #2.
D6TZ-3A713-E .. P/S Return Hose-Control Valve to Pump / Obsolete
1976 F250 4WD / 1977 F250 4WD (except 300 I-6) before production date 4/1/1977.
Thank you sir ! There are plenty of after marker return hoses, I was more concerned with a bad rockauto order I just received that had the wrong hose in it and wanted to cross check your # cuz I knew yours would be correct ....
