Rear axle options for a 65 F100 4x
I've got a 5 lug high pinon D44 disk front axle I'm going to swap into my 65. It's got 4:11 gears and I need to come up with a plan for the rear axle as mine is a factory 9" with 3:54 gears. I assume a later model 9" should bolt right in and would probably have bigger brakes. I need to stay 5 lug to match the front but have heard there is a D60.2 axle out there that has five lug pattern. With the 4:11 gears I'll likely go to a 33 or 35 in tire so maybe a D60 rear is a good idea. Any thoughts on how to come up with a 5 lug 60 or weather it's worth it. I'm guessing a later 4:11 9" would be a cheaper option and would probably have stronger shafts then my 65 with 28 splines.
You might have to move the spring perches on a later 9 inch rear end as the frames started getting wider when you move into the 73 to 79 range if I remember correctly. I have a Dana 60.2 and I quite like them however some people pointed out the parts are getting a bit harder to find for them as it is not a full floating rear end. The gearsets should be the same as a three-quarter ton diff but the axles will not be.
The Dana 60.3 (1966/69 F100) uses the same R&P's (C6TZ-4209-E/C6TZ-4209-F) as the 1966/85 Dana 60 (F250).
The Dana 60.2 (1963/66 F100) uses unique R&P's (C3TZ-4209-AH/C5TZ-4209-G). Both of these Dana's were available with a 3.54 or 4.10 ratio.
1953/67 F100's have 11" x 1 3/4" rear brakes. 1968/79 F100's have 11" x 2 1/4" rear brakes as do 1975/96 F150's. 1980/83 F100's could have 10" x 2 1/2" or 11" x 2 1/4" rear brakes.
Some 1980/83 F100's have 5 lug wheels on a 4.50" bolt circle, some have 5 lug wheels on a 5.50" bolt circle.
1965/72 F100: The width between the inner frame rails behind the cab is 33 1/2."
Beginning in 1973, the F100's width between the inner frame rails behind the cab is 37 1/2" as is 1975 and later F150's.
ALL the internal parts are hard to find except the axle bearing and seal.
These two parts are the same: 9 inch, Dana 44/60.2/60.3 .. except 1968/69 Dana 60.3 that uses a different seal.
The Dana 44/60.2/60.3 all have Limited Slip. 9 inch wasn't available with Limited Slip until 1968.
What is the rear axle ratio of this Dana 60.2? If it's 3.54-1, where will you find a 4.10-1 R&P to match the 4.11-1 front driving axle?
Personally, I would shy away from one of these Dana rear axles, due to the scarcity of parts.
BURNS FORD in Burns OR has 2 = 541-573-7278.
MILLER OBSOLETE PARTS in Binghamton NY has 10 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 96 = 800-543-4959.
B5TZ-4676-A =
MILLER OBSOLETE PARTS has 7.
GREEN SALES CO. has 22.
