Popped-Out Wall Panel
on
What is the easiest way to fix this minor issue while still looking decent? It appears the RG-6 cable routed up to the jack is pushing the wall panel away from the frame. This wall is the driver's side outside wall in the front bedroom. It's been like this since I bought it back in March, but I'm just getting around to fixing little minor things like this that have been bugging me.
How much pressure is on that joint? How was it fastened to start with? Sometimes a pneumatic finish nailer will work and sometimes I have used a pneumatic stapler, but you will either have to pull the tape back and then glue it over the staple or use some putty like you use to hide nails in finish wood work. You can also order the tape, although the roll is huge.
Steve
Steve
Steve
northwindone
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
06-15-2016 08:01 PM
jimdandyf100
07-17-2014 06:48 AM
