Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
73 F700 vin decode
Old 06-29-2010, 02:25 PM
DTB 73 F700's Avatar
DTB 73 F700
DTB 73 F700 is offline
73 F700 vin decode
Hi all I am looking for a decode on my grain truck. The vin is F70EVR54727 and it looks like the engine is original but not sure what it is. Thanks in advance TB
Old 06-30-2010, 07:30 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Welcome to FTE
F70 = F700 (gas).
E = 361 2V FT engine.
V = KY Truck Assembly Plant.
R54727 = 1973.
Old 07-28-2010, 02:26 PM
ernsetp's Avatar
ernsetp
ernsetp is offline
vin decoding
I have a similar problem, It is a 1979 F700 Dump truck with a vin # of F70AVEA7948. I am trying to find out what size the motor is. It has a V8 with a 2bb Holly carb made for Motocraft that I would like to find a rebuild kit for. thanks for any help...
Old 07-30-2010, 08:32 AM
NumberDummy
Welcome to FTE
F70 = F700
A = 370 2V
V = Kentucky Truck Assembly Plant
EA7948 = 1979.
D9PZ9A586AD .. Carburetor Kit (Motorcraft CT1278) / Obsolete
Fits all 1979 trucks w/a 370 2V with or without CA emission.
High Buck! BOB ALLEN FORD in Overland Park KS has ONE = 800-676-0675.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
Edit: 607-722-5371. Their 800 number is no longer valid.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
Bob Allen is close to you, but wants mega-bucks for obsolete parts.
Since all three sources have 800 numbers, call around for the best price. There are no set prices for obsolete parts, so the sky's the limit.
Old 07-30-2010, 01:09 PM
ernsetp's Avatar
ernsetp
ernsetp is offline
Thank you very much for the good information. I called the numbers you gave me for the carb rebuild kit. Bob Allen Ford wants $65. plus shipping, Green Sales wants $35. + shipping I presume. Miller Obsolete parts was the wrong phone #.
So I ordered from Green sales! I got one from Napa for $53. but will return it as they were not sure it was the right one. It has a Napa# of 2-5842 with a number on the box of 15724. The instructions say it is for a Holly Model -2300 EG. I couldn't find much on the carb itself except it says Holly made for Motocraft and the number stamped on the horn is: 6R 5544B. Thank you again... Ernie
Old 08-30-2010, 11:24 PM
DarqAce's Avatar
DarqAce
DarqAce is offline
I also have a similar problem. I'm trying to sell a 1980 F700 Grain Truck. I know it has the original motor in it but I have no idea what size/horsepower it is. The VIN # is K74NVHK1520. That'd be awesome if someone could help me out. Thanks!
Old 08-31-2010, 06:36 AM
NumberDummy
Welcome to FTE
K74 = F700 (diesel).
N = 8.2L Detroit Diesel.
V = Kentucky Truck Assembly Plant.
HK1520 = 1980.
Old 08-31-2010, 08:33 AM
DarqAce's Avatar
DarqAce
DarqAce is offline
Thank you very much! That definitely helps me out a lot. So now I know it's a V8 8.2L Detroit Diesel. Is there anyway I can find out what the horsepower of the engine is?? Thanks!!
Old 10-06-2010, 07:19 AM
ajone584's Avatar
ajone584
ajone584 is offline
also having problem here.Have f70evv70083,dont bknow engine size or year model.Would appreciate any help.thanks
Old 10-18-2010, 04:10 PM
NumberDummy
Originally Posted by ajone584
also having problem here.Have f70evv70083, dont know engine size or year model.
F70 = F700.
E = 361 2V
V70083 = 1975.
Old 10-19-2010, 06:45 AM
ajone584's Avatar
ajone584
ajone584 is offline
Thanks ,this will be very helpful. MH
Old 11-17-2010, 01:17 PM
bideawee01's Avatar
bideawee01
bideawee01 is offline
Question I am also having the same problem on my engine size Please help
F60DVR02113
WB 182
Color V
Model F602
Body 48
Tran A
Axle F23
GVW LBS 19200
DSO 280709
Thanks so much in advance..
Old 11-18-2010, 05:39 AM
NumberDummy
Originally Posted by bideawee01
F60DVR02113
WB 182 / Color V / Model F602 / Body 48 / Trans A / Axle F23 / GVW LBS 19200 / DSO 280709
Welcome to FTE
F60 = F600 2WD
D = 330 2V Heavy Duty FT engine (there's also a 330 2V Medium Duty (VIN code C) FT engine. It is not the same engine!
R02113 = 1973.
182" Wheelbase.
V = Dark Green.
F602 = F600 2WD, 19,200 lbs. GVWR
48: 4 = Black Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F23:
F2 = Eaton Model 15201 Two Speed Rear Axle / 5.83/8.12-1 / 15,000 lb. Rear Axle Capacity.
3 = Ford Front Axle, 6,000 lb. Front Axle Capacity.
19,200 lb. Gross Vehicle Weight Rating.
280709:
28 = Louisville KY Ford District Sales Office, where the original selling dealer ordered the truck from.
0709: Domestic Special Order number. The truck was special ordered by the original puchaser, not "bought off the lot."
Old 11-18-2010, 11:40 AM
bideawee01's Avatar
bideawee01
Smile Thanks
Thanks so much, that is great info, My grandfather bought this truck new in 73, thats cool that he special ordered it. He sold the truck in 1980 and died in 84. I ran across it sitting in a field, It still had his name and phone number on the door! I could not believe it, I had to have it, purchased it for 800 bucks. It started right up and runs perfect no smoke no oil leaks, hard to believe but it has 102000 miles. Does no look like it ever had a bolt turned on it. Anyway thanks again for your help I would have never found all that out, Thanks Sherman.
Old 10-26-2011, 01:39 PM
kevinksu2005's Avatar
kevinksu2005
kevinksu2005 is offline
I have one too if you don't mind: 1(E or f)DNK77N9FVA65799
I am looking at buying a truck and it is supposed to be a 1985 Ford F700.
I would like to know first if it is. Second what motor we're talking about. Third a little info for the shipping company. Approximate empty weight with a flat bed, top of cab height, width at front fenders.
Quick Reply: 73 F700 vin decode
