89 f250 7.5l 460 Coolant Temp Gauge Problem
Old 11-07-2016, 10:09 PM
Anthony Bauwens's Avatar
Anthony Bauwens
Anthony Bauwens is offline
My Coolant Temp gauge has always read to be low since I purchased it a year or more ago. I recently replaced the Coolant Temp Sensor and Coolant Temp Sending Unit. Neither of those fixed the gauge to read. I also replaced the Thermostat and flushed the Radiator. THAT... still did not help bring my gauge to read anything. I am all out of guesses other than a wiring fault/short, I am not doubting that that may be the problem, but everything looks good to me. Also, the oil pressure gauge does not work either but the battery and fuel gauge works. What else should I take a look at that I might be missing.
Old 11-08-2016, 03:51 AM
jplinville's Avatar
jplinville
jplinville is offline
Do you have the proper thermostat installed? Mine did that, and putting a proper temperature thermostat in brough the needle into the proper range.
Remember...these gages are more like dummy lights than they are proper gages.
Old 11-08-2016, 08:39 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Originally Posted by Anthony Bauwens
...I recently replaced the Coolant Temp Sensor and Coolant Temp Sending Unit. Neither of those fixed the gauge to read...
This generation truck uses a single wire sending unit for the temperature gauge. If what you changed has more than one wire, it was not for the gauge & more likely the temp sensor for the ECU.
To test the gauge, unplug the single lead & with the key on ground the conductor. If the gauge swings to H it is working & the sender is most likely bad or there is a large amount of corrosion where it is screwed in. If the gauge does not move, there is either a problem in the wiring or the gauge itself.
Welcome to FTE & good luck.
Da_Lariat_Chariot
06-28-2016 04:01 PM
78fordguy
09-05-2014 01:36 PM
tommyl
02-22-2012 08:09 PM
icuhatn99
08-23-2007 08:34 AM
96ranger_dallas
1983 - 2012 Ranger & B-Series
03-26-2005 05:55 PM
Quick Reply: 89 f250 7.5l 460 Coolant Temp Gauge Problem
