351C Vs. 400 rocker ratios
So i am rebuilding my 400 and want to do roller rockers when i do this. Roller rockers for the 400 are around 280ish for a set and 351C are around 200 for a set.
I know alot of the parts for interchange yet are the valve lifts the same (which would effect the rocker ratios switching from 400 rockers to 351C rockers) i have this makes sense.
Valve lift / cam lift = rocker ratio
these numbers are made up
400:
.8546 / .494 = 1.73 (1.73 is stock ratio or what ive read)
351c:
.4273 / 247 = 1.73
See how these ratios are the same but the valve lift and cam lift are different. if you switched the two rockers would they yield the same ratio. i believe they would but i am not 100% because a ratio is a ratio no matter what.
hopefully this made sense.
400:
351c:
.4273 / 247 = 1.73
These around $180
https://www.summitracing.com/parts/c...HqFRoCrIHw_wcB
These are $280
https://www.summitracing.com/parts/s...view/make/ford
I know these are two different brands so obviously there might be some price range. But i found the scorpions when searching the ford 400 motor and found the comp cam ones when searching 351C.
These are $280
78ford_shortbox
03-01-2006 01:34 PM
fozzy
09-08-2001 10:47 PM
