Weak hpop? High Pressure oil leak?
Old 10-31-2016, 08:59 PM
BstangBill's Avatar
BstangBill
BstangBill is offline
Hello, my 03' 6.0l hpop only makes about 1700 psi at wot, at hot idle the ipr is 25.1 and the icp is about 580. It runs pretty good but it seems the crank time to start is getting a little longer sometime's, other times it fires right up. It makes no difference if its hot or cold. Do pumps get weak or do you think I have a leak?....Thank You
Old 10-31-2016, 09:08 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
Early 03/04 HPOPs are know for failure. The pump should make nearly 4000 psi, 1700 is well short and the IPR at 25.1% is indicative of a leak. ICP at 580 is average for hot idle, but the IPR should be closer to 21-23%, 25% is high.
zeke37
06-01-2019 09:34 AM
maretta
09-25-2018 10:17 AM
maw8511
10-31-2017 09:41 PM
jereli
11-29-2011 03:29 PM
M.Farragher
10-15-2010 05:35 PM
Quick Reply: Weak hpop? High Pressure oil leak?
