93 351 W Mild build.
There is a current thread covering your questions a little further down the list. Tons of good info.
My main concern is how much I can shave the heads and bore the cylinders if it hasn't be done already.
Searching last night I got confused on speed density, some say you can't run a bigger cam and some say you can, so I wanted to ask because not getting a straight answer, and a lot of threads are older.
Still an EFI build. I believe there are more photos and info in the Performance forum. Found it: https://www.ford-trucks.com/forums/1...questions.html
While this is a build using a roller cam the same guidelines still apply for a flat tappet cam.
You don't want a "big cam" in a truck anyway. It'll pull hard mid range but it'll always have to crack a downshift to keep it moving at cruise. The speed density cams are actually very good for a truck application, and when combined with good flowing heads, are actually quite potent from idle to 5k.
No, this one: https://www.ford-trucks.com/forums/1...et-minded.html
