390 Rebuild
390 Rebuild
I am looking to rebuild my fe 390 (stock). It sits in a 1968 ford f100 and is connected to a c6 tranny that has been rebuilt....no shift kit, no stall converter.
The rear end on the truck is the dreaded 9 3/8, 3.25 gears and 31 spline axles. I'm really just wanting to have a cruiser, but would like for it to make the tires chirp some on the low end. I'm very much a novice but have a friend who is good mechanic and offered to rebuild the thing for me free of charge. Questions I have:
I have read that you can just pull a 9 inch center out of a Ford rear end and drop it into the 9 3/8. I may do this but what gear ratio would I want to be able to spin the tires a little on the low end and still keep my high end.
Or do I need to be looking elsewhere? I know I'd like to change that mammoth cast iron intake out for an aluminum intake, put 4 barrel carb on it, electronic ignition and headers. But what intake, how big a carb etc.....
Thanks
Thanks
If you build a decent 390, you will be able to fog the tires with the 3.25s.
I am pretty sure you can swap a 9" carrier into that housing no problem. You would, of course, have to match the axle splines and the u-joint.
For your engine, you do not want "stock" pickup. That gets you a down-the-hole piston with 8ish or worse compression. Go "stock" '66-69 390 GT. 9.5 to 10ish compression, a mild cam, 750ish vacuum secondary carb, Performer intake and headers.
There are multiple--heck dozens to hundreds--of FE builds described in this forum. Scroll down a bit.
Dad's old 68 had a Dana 60, my 73 and 78 both had a 9", I wasn't aware they used the 9 3/8" in a pickup.
3.25's are a good all around gear, I've ran them in several different vehicles.
Unless your building a full race engine a 600-750 vacuum secondary is plenty. My 73 had a 428CJ in it that I used a 600 vacuum secondary on and it ran well, in a car I'd have used a 750.
Are you sure you have a 390 instead of a 360?
Mister_King
11-25-2014 08:06 AM
76fordfan
16
01-10-2006 04:52 PM
ramboss429
03-09-2005 12:45 PM
1976F2504X4
08-05-2004 10:12 PM
