'87 F150 not starting, Please Help!!!
I bought a 1987 F150 that is not cranking or even clicking...I changed the battery, changed the starter and changed the solenoid...and it wont even click, but the dash gauges work, lights work....please HELP....any ideas what it could be or what I can check next?
Ditto to what Lead Head said.
Odds are this quick and very simple test would have saved you the cost of that new starter & solenoid
The wire from the ignition switch to the starter relay/solenoid is probably red/light blue stripe & probably has a slip on rubber boot.
Remove the boot & jump 12 volts to that pin. Does it crank? Be sure it's in park when you do this & leave the ignition switch off.
