1993 f150 wont start?
My 1993 f150 5.0 wont start. When you turn the key all that happens is a click. i jumped the solenoid with a screw driver to make sure it was getting power and i think the click was coming from the starter? is this a sign of a bad starter? And yes my battery is not dead.
-Ryan
-Ryan
Yes sorry for not adding that, have tried jumping it same issue. this has happpened once a long time ago but it only clicked once then started right up.
do a thorough check of the battery cables ... they are known to corrode to the point where they are not passing enough current to operate the starter. cut away some of the insulation in order to really see how they look. remove the cable from the starter and clean up the connection really well.
Or you can have someone crank the truck while you beat on the starter with a screwdriver to see if it will fire. If the battery is too far gone it won't do anything. Can you still use radio, lights, etc.? Best way is to put a voltmeter on it or jump the truck and drive to your local parts store and have them test the system.
My bad, I skipped your follow up post. I had a '00 Grand Cherokee did the same thing once and then again months later. It was so rare/infrequent I never bothered with digging into much. Assumed it was a bad spot on the starter and/or a cell in the battery fading. Again, I would get a check up at an Advance to be safe, but not worry much.
This works if it a problem with the brushes. I have had better luck with a hammer though. Check the connection at the starter. The noise you heard was probably an arc.
84F150Tank
22
03-21-2006 10:58 PM
Woodster
1983 - 2012 Ranger & B-Series
09-16-2003 11:44 PM
