Dually fender lights
Hey all,
I recently picked up a 91 f350 with the 7.3 Diesel. All the lights work except the fender markers. Does anyone have a good wiring diagram?
I saw a thread on here for the same problem but it was a 93. I read the fender lights are on their own circuit but I'm having trouble finding where that circuit goes when it heads towards the engine compartment and which fuse they would be.
Someone who owned this truck decided to play electrician... The amount of Scotch-lok connections on trailer harness is appalling.
he said NOTHING about the whole truck not having marker lights, JUST the dually fenders which are on the same circuit as the rest of the running lights
Wow sorry I didn't realize this would cause such debate. I could have "made it work" but I wanted to fix it instead.
After digging around I finally found a good wiring diagram. Apparently the fender lights run through the trailer wiring relay... Luckily that's all the problem was, local parts store actually had the relay in stock and I replaced it and the fender lights work now.
F350/ranger phil
12-10-2018 08:45 AM
bossmanbef
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
04-05-2003 06:36 PM
