What are you using for shifter boots?
Old 10-23-2016, 06:17 PM
hail destroyer's Avatar
hail destroyer
hail destroyer is offline
I know we got some creative folks here. No one wants to pay 35 for a shifter boot and 35 for the retaining ring, so let's see pics if your manuak trans shifter boot solution s. Thanks!
Old 10-23-2016, 07:16 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Hurst shift arm on my TKO... 70 Hurst boot and trim ring.
I've made one using vinyl, a hose clamp on top, and a bottom frame bent from a coat hanger... the boot is folded inside out and the upper neck clamped on the arm. Then the boot is pushed down... gives it a nicely dressed edge. Then the bottom of the boot clamped under the trim ring. Try it... you can sew, right???
Old 10-23-2016, 09:28 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,348 Likes on 2,490 Posts
X2 on that seems like a cheap and easy reproduction for about any local upholstery shop. As far as the chrome rim for cheap...JY lap time is the cheapest. I have about 5 of each just setting on the shelf.
93 mix 'n match
08-16-2009 01:19 PM
tsheriff
1999 to 2016 Super Duty
03-15-2006 08:20 PM
Quick Reply: What are you using for shifter boots?
