U Joint & Center Support Part Numbers & Replacement
I am trying to determine the correct U joints for my 1994 F150 super cab 2wd 5.0 4R70W. It has a 2 piece driveshaft with a center carrier and 3 U joints. I would prefer Spicer U joints, but will probably settle for Moog if necessary. I see several listed on Summit and other sites, but none seem to specify the location. Does anyone happen to know which ones are correct or know of a website that lists them?
I can't lay hands on the boxes (buried, I guess) , but I believe I used the 345, (no zerk) outside snap rings.
Should be the same from 5.0 to 5.8 super cabs, but its ford so who knows.
If you can pull one, you can get the measurements if you want to order them or take it to the counter.
http://www.moog-suspension-parts.com...ts-ujoints.asp
http://www.driveshaftspecialist.com/...D%20Guide.html
http://spicerparts.com/resources/measuring-u-joints
Yeah. Dropped it off at my local drive-line shop since there are more than one incident here about issues others have had changing them.
Bout' 160K+ here:
Make sure you mark clearly all the orientation of all the joints & flanges to avoid balance/phasing issues.
Others say it doesn't matter. I didn't chance it.
Bout' 160K+ here:
mrcman58
Ford Truck Parts for Sale
01-02-2016 09:20 PM
smokey6309028
08-01-2003 04:04 PM
