302 to 351w
302 to 351w
I have a 94 Bronco that had a 302 I swapped it for a 96 351 w. It drove ok for a week but then it slowly started having shifting issues and would not accelerate. My mechanic didn't switch the harness or computer. Do I need to swap the harness and computer to make it work properly?
I have a rebuilt E40D 4x4 tranny
some 94 model 302 bronco's had mass air while others still ran speed density. which efi is on the bronco?
if speed density, the plug wire firing order is all that is necessary.
if mass air, the injector harness must match the 5.8 firing order if running the 5.0 computer along with proper plug wiring order.
i suspect you installed the correct 5.8 flexplate for the e4od.
Conanski has sound advice
Manic Mechanic
04-16-2008 08:23 PM
