Evening guys, anyone have a good source for quality replacement western swing away side view mirrors like what I have on my truck? My lower brackets are starting to rust...... Thanks.
These are the first two that come to mind. You could also try a junkyard, but they may be just as bad as what you have now.
Red
Thanks Red, generally I stay far away from LMC junk.. I've never tried NPD. Junk yards around me dont have chit; all the old stuff was crushed years ago. Too much rust on stuff for it to be worth anything.
These are the defunct Warn flares, stopped making them years ago.. I was lucky enough to find another set of brand new ones that took me eons to find. Bought them from a parts store in Canada last year..
The top flange is above the bracket on that generation, whereas it's below the bracket on the OBS. The hole spacing on that flange MIGHT not be the same. I have one OBS and one slantnose at home, each with the swing-aways, and if I don't forget and it's not pouring rain tonight, I'll compare.
Sun is shining this morning (and I forgot until just now anyway....), went out and measured. Hole spacing across and top-to-bottom are the same between the '85 with the flange "up" and the '95 with the flange "down". So even though a flange-up mirror won't visually be "right" for the generation, it should fit.
