where to find a replacement shaft.
Old 10-04-2016, 06:53 PM
tominiowa's Avatar
tominiowa
tominiowa is offline
my son crushed the yoke on his front right outer dana 44 shaft. all the ones I can find are 19 spline and his is a 30 where do I look next
Old 10-04-2016, 07:07 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by tominiowa
my son crushed the yoke on his front right outer dana 44 shaft. all the ones I can find are 19 spline and his is a 30 where do I look next?
Please, when asking questions, list ALL the pertinent information.
What year is it, what series? What is the engine size and transmission type?
The Ford AXLE ID tag is located under two of the bolts that retain the inspection cover to the housing.
It would be very helpful if you could post a pic of it, or type the info that's stamped on it, but by now...it may be missing.
Old 10-04-2016, 08:18 PM
tominiowa's Avatar
tominiowa
sorry, 1982 f250 with 351 and 4 speed. I can on axle tag tomorrow, shaft is approximately 9.875 long from end of spline to center linr of yoke and has 30 spline not 19
Old 10-05-2016, 10:07 AM
NumberDummy
Ford truck parts catalog doesn't list the spline count.
The only way I can give you the Ford part number is with the info stamped on the ID tag.
Generic pic from 1980/89 truck catalog:
Old 10-05-2016, 06:53 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,716 Likes on 1,387 Posts
Hmm, I wonder that little triangle means when it says "from 8-82". Do you reckon that is why you can't find the right part, you have a early 82 model?
Old 10-05-2016, 08:28 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
WhatsAChevy? is offline
Wouldn't be the first time that a production date came into play....food for thought.
Old 10-05-2016, 09:59 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
That's a VERY good possibility here!
You have to find that downward-pointing triangle in the diagram to match up with the textual explanation down at the bottom. And that down-triangle is up in the top-left corner and is specifically pointing at the front drive axle.
OP: What is your production date? This will be on the Certification Label on the driver's side door jamb.
Old 10-07-2016, 10:41 AM
tominiowa's Avatar
tominiowa
I was wrong on the part I actually need, after looking at the diagram that NumberDummy posted, I am looking for shaft 3N387 it slides into the differential.
What is that shaft called?
Old 10-07-2016, 10:49 AM
ctubutis's Avatar
ctubutis
ctubutis is offline
If you provide your axle tag information, ND Bill be able to give you all sorts of wonderful information....
Old 10-07-2016, 07:10 PM
NumberDummy
I was wrong on the part I actually need, after looking at the diagram that NumberDummy posted.
I am looking for 3N387 INNER SHAFT YOKE .. it slides into the differential.
There's more than one, so I would appreciate the numbers that are stamped on the AXLE ID tag.
After 1972, looking up 4WD parts in the parts catalogs is a real b!tch...without the AXLE ID number.
If the tag is missing (as usual), be prepared to answer a gazillion questions!
Here's a pic (look towards the bottom of the page) of the 1982 F250 4WD front driving axle applications. Look at all the crap I need to know to get the correct parts list.
Old 10-10-2016, 07:41 AM
tominiowa's Avatar
tominiowa
I found the shaft I needed at Woody's in WA. It is already on its way. That's for all the good info.
jakeharp
05-11-2018 11:15 PM
tandpr
10-29-2012 01:08 PM
johngeorge
Offroad & 4x4
05-28-2012 08:52 PM
jasonnerothin
07-06-2010 08:44 PM
Quick Reply: where to find a replacement shaft.
