1989 F700 No brake lights
Keep tracing. Maybe we can get a wiring diagram for you. Stay tuned.
When tracing, look for fusible links or circuit breakers. You may have one or the other, both or none.
The fuse panel should have a pretty substantial wire leading to it.
Also, check the grounding of the panel, and all other grounds as well.
I have a 97 f800 I've been battling for the past week, I have the same exact issue....have you found anything that was helpful yet?
russell christy
09-26-2013 06:27 AM
thabble
03-24-2010 01:22 PM
